losing boost at WOT
Old Oct 23, 2011 | 02:26 PM
ChrisW92410's Avatar
Default losing boost at WOT
first off let me tell you gus a bit about my car. its a 2000 audi a4 1.8t, gutted air box, apr stage 1 chip, apr exhaust, and suspension. from 2nd gear at WOT ill peak at 20psi fall to 15psi then fall to 5psi by 5200rpm, im unsure whats going on, im a former dsm guy so im not highly familiar with these cars. I was hoping someone on here can tell me whats going on so i can fix my loss of power issue im having here.
Old Oct 23, 2011 | 04:23 PM
turbo kraut's Avatar
Tech Guru
20 is your "spike" 15 is where you should be, the falling off to 5 is a leak of some sort. I would suspect a hose but what dv are you running?
Old Oct 23, 2011 | 04:54 PM
stock DV.
Old Oct 24, 2011 | 07:32 PM
ImTheDevil's Avatar
That's likely at least part of your problem.
Old Oct 25, 2011 | 12:16 AM
What would be the other half? N75, and boost leaks?
Old Oct 25, 2011 | 12:18 AM
car wont boost past 5psi as of today.
Old Nov 16, 2011 | 11:42 PM
Bump....
Old Nov 17, 2011 | 05:52 PM
evelluser's Avatar
Car went into limp mode. Try getting an upgraded Diverter valve and that should help. And check for vacuum leaks, those are a big issue. Try cleaning your MAF, too.
gold01A4
Apr 18, 2013 09:05 PM
phila1776
Apr 10, 2008 09:32 PM
ADubyaD
Apr 17, 2007 10:22 PM
itsquattro
Dec 12, 2006 09:47 PM
thizzwatitiz
May 15, 2006 12:19 AM
