Oil leak--repair advice
Old 05-01-2009, 09:08 PM
DEjunkie's Avatar
Default Oil leak--repair advice
I had my mechanic look over my car for preseason bolt-down & inspection. He found the source of 3 leaks. First one was one I have known for a while--power steering fluid. He suspects it is the high pressure hose but says it could also be the rack.
The other 2 are oil--valve cover and crank case vent pipes. My questions are:
1. Since they aren't leaking profusely, is there any risk in not fixing immediately.
2. Is there any upgrade I should consider when I do get these items fixed, or just use oem parts.
3. Any general watchouts?
4. He quoted $1000 to do all. Sound right (for both parts & labor)?
5. I found the valve cover gasket online, but not the crank case vent pipes. Is there some other name for these parts?
Thanks for any advice!
Old 05-01-2009, 11:30 PM
Midniteoyl's Avatar
$1000? Hope he wears protection.
Old 05-01-2009, 11:38 PM
cincyTT's Avatar
I'm make believe
valve cover gasket is like $45 shipped with the tensioner gasket and anyone can do it. The other leak you should add in a catch can and remove everything else from the pcv system. Here is l88m22vette's write up http://www.audifreaks.com/showthread.php?t=753
The sooner you fix it the better. It can and will effect performance and making a oily mess over everything. Also its under $150 in parts and can be done in a better part of a day for a first timer with no special tools
Old 05-02-2009, 01:07 PM
jakej's Avatar
$1000 is a lot for something most people can do them self.
Old 05-02-2009, 03:12 PM
Midniteoyl's Avatar
But if you cant, its cheaper than screwing up.
Old 05-02-2009, 03:31 PM
DEjunkie's Avatar
That's usually the way I think too. Especially since I have a 3 month old and time is difficult to come by.
But if Cincy is confident that a layman can do it, then I think I'll try it. I looked at the DIY, but I didn't see a detailed parts list. I'll do some searching. Thanks guys.
Old 05-02-2009, 04:14 PM
cincyTT's Avatar
I'm make believe
All you basically do is remove the coilpacks and then the valve cover. Its a little more involved on the 225 since they put all the **** on top of the valve cover thats under the intake manifold for other 1.8t's, but its nothing a good set of hand tools cant accomplish
Old 05-03-2009, 09:25 AM
DEjunkie's Avatar
Thanks Cincy. I'll be starting this work in about 2 weeks...be prepared for questions
2013A4
01-26-2015 05:33 PM
cneedelman
03-17-2014 05:17 PM
GRIDLOCK
09-11-2007 12:04 PM
mnaudi
10-27-2006 07:29 PM
NCMurphy
09-22-2006 04:26 PM
Quick Reply: Oil leak--repair advice
