Problem with new gauge....Help Plz
Old Sep 8, 2008 | 11:01 PM
keefboz's Avatar
i used the kit from 42dd and it works fine, i installed it myself and i know nothing about anything, so it cant be that hard!
Old Sep 9, 2008 | 12:19 AM
Mobius97's Avatar
Originally Posted by 01TT225Q
i pulled the gauge and found the line right at the back bent...so what oother line do i get?
I already told you.....some rubber vac hose from the parts store.
Old Sep 9, 2008 | 12:33 AM
ouTTie914's Avatar
Do what I did and make a notch /\ into whatever is causing the line to bend.
Old Sep 9, 2008 | 12:35 PM
myxyzxo's Avatar
SoCal Crew Member
What I did is this. When you removed all the channels from the vent. There will be 2 holes opposite from one another. I just sent the vacuumline through one hole and the light lines through the other. Tucked the extra wiring n hosing into dashboard. Then placed the vent back in. You shouldn't need to cut anything.
Old Sep 9, 2008 | 01:24 PM
01TT225Q's Avatar
well i just bought a coupler for the back of the gauge to convert to barb...now im going to run good rubber vac to the fpr t...now...what if it still shows this boost? what else would it be?
Joshuagr33n3_08
Aug 20, 2013 11:31 PM
Magic-Man619
Apr 8, 2012 11:18 AM
Schwaan
May 12, 2009 03:42 PM
andrewbb89
Aug 6, 2007 05:57 PM
jsgrabo
Aug 5, 2007 02:38 PM
