rear wheel bearings?
Old Nov 27, 2007 | 03:27 PM
zero388's Avatar
Default rear wheel bearings?
Well my rear wheel bearings are going bad. I heard that they would cost about $300-$350 per wheel. Is this true? Also how easy would they be to replace myslef and how much would the cost be if I did it myself?
Old Nov 27, 2007 | 03:30 PM
MeanAudiA6's Avatar
Default RE: rear wheel bearings?
its not too bad...time consuming tho...if you are familair with rotors then you should be ok...
http://ecstuning.com/stage/edpd/page...egory=Bearings
Old Nov 28, 2007 | 02:22 PM
MeanAudiA6's Avatar
here ya
just replace this and your good to go...this makes this hella more easy...just replace the hub and your good to go
go.....http://www.mjmautohaus.com/catalog/p...roducts_id=888
Old Nov 28, 2007 | 07:53 PM
jakej's Avatar
If you replace the entire hub, its nearly just one step past doing a brake job.
yellow_submarine
Mar 20, 2014 08:45 PM
Broncoman75
Jan 2, 2009 01:11 AM
onepoint8tee
Jan 7, 2006 04:33 PM
wombats3
Nov 15, 2005 09:45 PM
Dhenkel
Jul 11, 2005 03:58 AM
