Turbo valve question!
Old Dec 11, 2006 | 03:51 PM
TeeTee's Avatar
Default Turbo valve question!
Hello i have some questions about turbo valve witch is mounted together with turbo!
1) What is its function?
2) I made a diagnosis and they corrected a mistake of turbo valve and my car suddenly went better! ( Maybe my new air mass meter adopted to the ecu) When this turbo valve is broken or almost broken, is it a reason why car sometimes you push pedal goes or doesnt go????? Thanks
Old Dec 11, 2006 | 05:26 PM
rayveedub's Avatar
Default RE: Turbo valve question!
im not sure but it think you are talking about the integrated wastegate. if this is broken you need a new turbo. i wouldnt reccoment any quick fix.
Old Dec 11, 2006 | 08:59 PM
MeanAudiA6's Avatar
why do you say he will need a new turbo. even though its internal wastegate it only attaches to the turbo you can just replace the wastegate forge motorsports carries them. you might need a new turbo if the wastegate is bad and you've been running it hard like that.
Old Dec 12, 2006 | 12:44 AM
TTsteve's Avatar
Thats kinda the problem Im having. My turbo isnt kicking in and Im only getting 5 psi instead of 20. But it still is a little peppy just no turbo kicking in when I get into the higher rpms. I thought it might be an open wastegate but now Im not sure. I disconnected the MAF but couldnt really tell any difference maybe a little better. After X-mas I am taking the car to a good performance shop in ATL or SC and let them look at it. I should be close to 300 HP crank.
Old Dec 12, 2006 | 01:15 AM
Mikefc626's Avatar
TTsteve, what do you use to be able to know that you only get 5psi instead of 20, and how do you know that you should be close to 300 hp? I'm not questioning you personally, just trying to learn about these things.
MAF = mass air flow, right? Where is it? I almost asked "what's it do", but google + wikipedia = positively one of the greatest inventions ever
Old Dec 12, 2006 | 01:44 AM
XCLR8TT's Avatar
ORIGINAL: Mikefc626
You use a boost gauge to see your charge pressure on the manifold. Usually the gauge is connected to the line running to the FPR (Fuel Pressure Regulator).
The MAF is the sensor you see just downstream of the airbox.
Old Dec 12, 2006 | 01:45 AM
slowtruck's Avatar
ttsteve, i am having the same problem. i should be making about 15 but i am only making 5. disconnected MAF and no difference. if you find out what is wrong let me know and ill do the same for you.
07titanium
B7 Models
Oct 25, 2011 08:11 PM
idriveb5
Oct 24, 2011 09:16 AM
nycrca77
Mar 29, 2008 02:49 PM
cukilo
Jun 8, 2005 01:28 PM
FtMyersAudiFreak
May 25, 2005 11:35 PM
