Version 2.0.......T (Engine at shop!!!)
You dont need to do it to each runner why would you do that you would have to run fuel and nos to each one.run itbehind throttle body. Also a little hiding trick is run it through your coolant hoses keeps it heated up so your not blow torchingand also get a heat blanket.
ORIGINAL: ooantipostoo
^^^but like cincy is saying you wont get equal spray into into the cylinders...plus he will more than likely run a water/meth operation there too. so the throttle body idea i;m confused on.
gas and nitrous comes out the nozzle together and you have a fogger in each intake runner so you have equal distabution. With a wet shot, you still have gas injected with the nitrous and you can have 10/30/25/35 distrabution in each cylinder. NOT SAFE.
i;m talking about the NOS not gas...they get the same flow rate from the fuel injectors(direct port fuel injection) so for the cylinders to get the same NOS they would have to be directly supported by fuel as well. in the same area hence the name direct port injection....they wouldnt get equal flow doing it through the throttle body
