1st gear stuck
What is going on? Sometimes when im sitting at a light and go to put it in to first the shifter will only go in about half way or so. So what i have to do is shift into second then back into first to get the gear box into first gear... What can that be?
Mine does this sometimes too - my guess is the synchros are wearing out. Here's something you can try if you have fine clutch control: actively try putting it into first, but use only the normal amount of effort. Bring the clutch pedal near the engagement point, and slowly release it. Once the clutch hits the engagement point the shifter should pretty much pop into first gear. And when this happens press the clutch in to make sure you don't grind gears or anything like that.
Is your car Quattro? If I recall correctly the rear diff carrier or bushings or something like that could be worn out and cause this sort of thing.
Janissarie
Oct 18, 2007 06:56 PM
merlin12volt
Dec 14, 2006 05:51 PM
