98 a4 2.8 crank sensor bolt size
Old Jul 26, 2012 | 08:08 PM
elye1231's Avatar
Default 98 a4 2.8 crank sensor bolt size
Anyone know the bolt size for the crank position sensor on a 98 a4 2.8L manual?.. i was replacing it and when i located it i found that it had no bolt and just came out like that it was very loose...p0322 code if my research is good thats usually for the engine speed sensor. thanks in advance guys
Old Jul 26, 2012 | 08:21 PM
AudiDeficitDisorder's Avatar
I'm not sure what it is on mine. I have an ATQ engine and auto tranny but I could check if you wanted. I think your best bet would be to try to find the bolt you're looking for at a local junk yard.
Old Jul 26, 2012 | 08:31 PM
elye1231's Avatar
ill appreciate if you can check because im sure the actual bolt should be the same. but will you be able to tell the exact size ? not just if its a 9m 0r 10. thanks
Old Jul 26, 2012 | 08:41 PM
You mean like length, thread pitch, etc?
Old Jul 26, 2012 | 09:02 PM
elye1231's Avatar
Default yessir
mikeaagesen
Aug 8, 2014 12:13 AM
jason23silver1
Jun 24, 2009 12:20 PM
chefro
May 5, 2009 12:34 AM
99a4avant
Aug 11, 2007 12:23 AM
SSn
Feb 27, 2007 11:13 PM
