99 2.8 quattro - idling at higher rpms than usual?
Old Aug 27, 2010 | 04:56 PM
alexmurphy's Avatar
Default 99 2.8 quattro - idling at higher rpms than usual?
my car typically idles between 500 and 800 rpm, but the last 3 or 4 days, it has been idling around 12-1300 rpms. its almost high enough that if i put it in first and let go of the clutch it won't sputter out. this can't be good???
I noticed though that it usually goes away after about a mile of driving or so. The other day i noticed it, and i drove around my neighborhood and by time i was home it was back to normal. I'm still worried though. can anyone help me figure out whats going wrong?
Old Aug 27, 2010 | 04:59 PM
twoeightquattro's Avatar
that's odd. my 2.8 idles at about 800-1000 usually.
usually thats warm up mode up there but it shouldn't be that cold! haha
Old Aug 27, 2010 | 05:30 PM
alexmurphy's Avatar
well recently its been cold compared to summer weather here....and by that i mean 70-80 outside compared to about 100 that it has been the last 3 weeks.
Old Aug 27, 2010 | 05:33 PM
yeah it should'nt be idling that high, no idea what that could be.
Old Aug 27, 2010 | 07:30 PM
ImTheDevil's Avatar
Seafoam the vacuum system, pour half a can of seafoam into the oil, drive 100 miles, and change the oil and filter. You may have crap somewhere in there that's causing the idle to go high (maybe the EGR). See if that cleans it out. You can also unhook the battery for an hour and then hook it back up, turn the key on (without starting the car) for 60 seconds, and let the throttle reset. This will put the car in relearn mode and may help too.
Old Aug 28, 2010 | 02:53 PM
alexmurphy's Avatar
I noticed something else, when i first turn the car on SOMETIMES the engine and oil temp gauges both don't read anything. I noticed that, then revved the engine for a minute, and they eventually shot up with temps and the idling went down.
bikebarn5
B7 Models
May 20, 2008 04:09 AM
alan93
Jun 15, 2007 08:40 PM
HansBlix
Sep 15, 2006 12:37 AM
dhlafevers
Apr 8, 2005 07:56 PM
David_K
Aug 12, 2004 01:41 PM
