Alice's Progress
Old Oct 10, 2013 | 07:53 AM
  #71
Clayson's Avatar
Originally Posted by BaseDrifter
You didn't do the output test with vag com before sending it off right? I would've started there. At least then you could tell if the pixels worked or if the problem lies elsewhere. If Ian is saying there isn't anything he can do with it there isn't much for me to say. Those guys know a lot more about this than I do. They had no problem resetting the EEPROM for me though, same cluster.
See, that's where what he's saying makes sense. I did do output tests, and I can't remember on which one it was, but on one of the cycles, the display lit up REALLY bright. But it would never show any warnings, low fuel, etc. So I knew it was getting power, well I knew that because it wold show the lines before, and at that point I kinda thought the pixels were fine, because they all lit up, so I just thought it was some kind of error within the display.
Car looks good, ditch that badge on the grill though!
I'm torn! I know it doesn't belong there, but its always been there. If I take it off, I'll have to replace it with something else, maybe just a quattro badge.
I'm long overdue to give my interior a real cleaning. The carpets have never been thoroughly cleaned and my seats are looking a little rough.
Not that hard, really. Surprised at how well it turned out!
Old Oct 10, 2013 | 01:56 PM
  #72
Clayson's Avatar
Hahaha.... Hooked up a cluster from a "98 A6, I knew it wouldn't work. I think I'm the most bored college student ever. But the results were funny to say the least. What did I get? A CEL that doesn't know if it wants to stay on or off, a brake light that stays on, brake pad wear sensor warning, coolant level warning, a fuel gauge that think I have WAY more gas than I do, oil level warning, no tach, lights that stay on, ABS light, AirBag light, and oddly no A/C condenser. Oh and VCDS wouldn't detect it either. Is this what I would get if I put in a '98 A4 cluster?
Old Oct 18, 2013 | 08:11 PM
  #73
Clayson's Avatar
So... got a DIFFERENT cluster. It's doing the same thing!! It lights up, but won't display info. I emailed Ian to see what he says. I think God's just pissed at me or something.
Old Oct 19, 2013 | 01:53 AM
  #74
BaseDrifter's Avatar
Site Moderator/B5 Tech Guru
You should start looking at your wiring for the red plug. Double check that you have the pins in the correct locations, make sure the wires aren't damaged, etc.
Old Oct 19, 2013 | 09:03 AM
  #75
Clayson's Avatar
Yeah, planned on that today. But that still doesn't make any sense, because the A6 cluster worked perfectly. I could flip through all of the menus before all the errors came up. Is there any way that they like "lock" themselves after so long of not being used?
Old Oct 25, 2013 | 03:09 PM
  #76
Clayson's Avatar
Got all the V-Dubs together today. It'd be perfect if I could get ahold of my uncles Porsche too...
Old Oct 25, 2013 | 03:21 PM
  #77
mtroxel's Avatar
A German family reunion!! Any good family fights?
Old Oct 25, 2013 | 03:56 PM
  #78
Clayson's Avatar
Come on, it wouldn't be a true family reunion without a few fights!
Old Oct 26, 2013 | 03:31 PM
  #79
Clayson's Avatar
Does anyone know what this is supposed to attach to? I started to hear it whacking the window inside the door whenever its down.
Old Oct 26, 2013 | 06:39 PM
  #80
mtroxel's Avatar
Does the outside door handle still work on that side?
