automatic worth boosting?
Old Feb 19, 2008 | 09:31 PM
  #31
cincyTT's Avatar
I'm make believe
Default RE: automatic worth boosting?
I would go steel and have someone weld everything for you. You need to have the map flange match the piping used
Old Feb 19, 2008 | 09:35 PM
  #32
Leifer's Avatar
Ordered. I bet the custom exhaust shop could do that; I'm going to have them conjure a new 3" TIP for me to use too, so might as well see if they can weld the IC piping together.
Old Feb 19, 2008 | 10:05 PM
  #33
cincyTT's Avatar
I'm make believe
that would be wise. Im betting if you hang the ic and show them or have the pipes cut, they will weld the ic piping for you also
Old Feb 19, 2008 | 10:19 PM
  #34
chaos92287's Avatar
ORIGINAL: Leifer
yeah most shops should be able to do it. i just cut and testfit the pipes using a silicon connector, then brought it to the shop and told them to weld it like that. 10 bucks and 10 minutes later, i had it back and installed it on the car
Old Feb 20, 2008 | 04:04 PM
  #35
osterthetoaster's Avatar
how much does a tiptronic cost to get installed and to buy?
Old Feb 20, 2008 | 04:21 PM
  #36
cincyTT's Avatar
I'm make believe
you talking about a replacement? You might be looking at about $2k-3k for a used one and installed at a local shop
Old Feb 20, 2008 | 05:15 PM
  #37
yeah thats what i meant, ok thanks man
Old Mar 26, 2009 | 02:09 PM
  #38
402ghost's Avatar
this post is beyond helpful.
Originally Posted by qUaTtRoA4
I would go with a GIAC chip $450 first (you will need to get a diverter valve at the same time)
forge/bailey DV- $150(alot of the time when you go to a local "tuner", they will give you a deal if you buy the chip and dv at the same time)
FMIC- $320 (custom godspeed set-up, some DIY involved)
Custom exhaust- $350 (2.5" exhaust piping, running to a magnaflow muffler, with a nice set of tips)
LaBree HFC/DP/TP- $100-250 (depends on emmisions in your state (if you have to smog you need a cat))
thats a pretty good start-up list....you should look into a tip chip (altlhough I am not sure if one is available for a '97)
And if you plan on making bigger power, the road that most atomatics take is LEVEL TEN
you can search on here and research more before making any decisions
NOTE: If this car is new to you , have it checked out, it is an 11 year old car...this is when the control arms go, motor mounts, tranny mounts, cv boots, oil cooler...and the list goes on and on...somewhere between 90-120K a lot of the parts I listed go out....along with gaskets and seals....
before performing a single mod, make sure that all of you maintenance is taken care of
here is another good site that you should take a look at audidiy.com
there are also many free mods available for our cars, just take a look in our DIY section....I remeber reading somewhere that you can convert a regular auto to a tiptronic...sounded kinda cool
alright, well, I hope something up there made some sense
gl!
Old Mar 26, 2009 | 03:04 PM
  #39
ghost6303's Avatar
it is helpful, although all of it can be found in the stickies which everyone should have read by now.
Warny
May 17, 2012 07:38 PM
MyDreamCar
Aug 2, 2009 06:43 PM
osterthetoaster
Feb 18, 2008 03:34 PM
nokiamutt
Dec 14, 2007 11:42 AM
yoon
Jun 4, 2004 03:32 AM
