Check Eng Light = Mult. Misfire. Now won't start
Hey Guys,
I'm new to Audi's (not VWs - have a Touareg).
Just bought the car, here's the scenario:
1997 A4 Quattro 2.8L 5spd
163000 miles
Check engine light came on, multiple mis-fires. I changed spark plugs and wires, ran fine.
Next day it died while driving then started again while in gear doing 50 MPH.
Parked it and it wouldn't start.
Towed it home, now there's no charge on the battery and starter is bad.
My initial thoughts on diagnosis:
What else could cause those issues?
Thanks for your help.
163000 miles
- Alternator Bad
- Starter Bad
- Ignition Coil
Hey Guys,
163000 miles
163000 miles
- Alternator Bad
- Starter Bad
- Ignition Coil
He checked everything! Replaces coil pack, plugs, wires, starter, battery
Only explanation I can guess on your car is ICM (ignition control module)
I found why my charge was bad, the previous owner broke off the bottom bolt that holds the alternator in place, causing the tension on the alternator to be very weak = no charge.
Starter was also bad.
I've put it back together and will start it tomorrow. Hopefully it will turn-over.
Do you know when the battery is disconnected and then reconnected if I need a Vagcom for any reason?
Car is running great after all of the minor adjustments I made in one week.
For now, everything seems to be working just fine. Thanks everyone for your help!
domenicostorino
Nov 12, 2009 12:56 AM
jfree212
Feb 4, 2009 09:14 PM
