Clutch Slipping
Old Oct 12, 2008 | 08:24 PM
vtraudt's Avatar
Default Clutch Slipping
A new clutch was installed (all OEM, including rear main bearing and flywheel) a year ago.
Today, I verified that once RPM get over 3500, the clutch slips (revs climb fast), most noticeable in 3rd, 4th and 5th gear.
The clutch has only what feels like 1mm of travel before it disengages (was like that from the beginning; no change as far as I can tell).
What could be the cause of the slippage? Surely, the clutch is not worn out already (first one was good for 100k+ miles).
Any advice?
Old Oct 12, 2008 | 09:08 PM
qUaTtRoA4's Avatar
sounds like it was never done...
sounds like it is time to get a stage 3 and DIY...
sorry to hear the sh!tty news...I just got a new clutch 6 months ago...I would take my car back to the guys who did it and have them replace it....I think a good deal would be for you to buy the clutch ad have the shop do the labor for free...
gl!
Old Oct 12, 2008 | 11:26 PM
flynnr's Avatar
my clutch is out too.... i have 104k right now so i think it was time regardless!
but what is a good (but inexpensive) clutch kit (including pressure plate) that i can buy???
i would likely DIY but i need to know what to buy first! i like the stock feel, and probably wont ever drop the clutch for any reason ( i dont race or anything) so i dont really need a stage 3 or anything by any means... but i dont want mine to go out after a year (like the orriginal poster's did) so i was toying with the idea of stage 2...
so what im getting at is .... good priced oem replacement (stage 1 or whatever) and a good priced stage 2 so i can compare and decide what to get! any advice or comments would be helpful
Old Oct 12, 2008 | 11:27 PM
cincyTT's Avatar
I'm make believe
could of been a bad install, reused the old throwout bearing, or you could have fluid on the fw. Not really much you can do. I would of gone with a single mass fw and a slightly stronger clutch so it could hold power better.
Of course, you could also have problems driving..... kidding... mostly
Old Oct 14, 2008 | 08:58 AM
vtraudt's Avatar
Default Hydraulic Clutch Fluid?
I don't have the manual at hand, but is there such a thing as a clutch fluid reservoir that needs to be checked and refilled?
Old Oct 14, 2008 | 04:53 PM
ImTheDevil's Avatar
The clutch and brake fluid share a reservoir.
Old Oct 14, 2008 | 04:57 PM
vtraudt's Avatar
Default Clutch Slippage - low or bad brake fluid? Air?
If brake and clutch share the same fluid, could
- air in the lines
- low fluid
- old/poor condition fluid
explain the behavior (1 year old clutch slipping)?
Old Oct 14, 2008 | 05:22 PM
Mike-2ptzero's Avatar
If there was air in the system it wouldn't cause the clutch to slip. Only thing that will cause slipping is a warn out clutch disk or a pressure plate that has lost too much tension. Just sounds like its time for another clutch.
Southbend clutch kit for those that need one.
Old Oct 14, 2008 | 05:29 PM
Jc61990's Avatar
under FE SS Stage 5 it says
With Feramic on both sides of the disc,
is that a typo?
actually i just noticed now it says it in a lot other spots too
Ncbaca
Nov 2, 2012 07:42 PM
fireman9585
Jun 19, 2012 03:49 PM
kartboy
Feb 19, 2010 12:28 AM
bigern45
Feb 13, 2009 09:55 AM
FRO
Jul 26, 2006 10:15 PM
