complete engine loss!
Old Dec 12, 2008 | 09:18 PM
legendpilot's Avatar
Default complete engine loss!
as i picked up my a4 from the shop it completely died on me, i wasnt even 1/2 mile away from the shop. while at the shop the mechanic found a bunch of the vaccum lines damaged or not even hooked up. he also shut off my airbag light, he even drove it around to make sure its ok and it was fine. now before it died on me it made a wurring sound and lost all power. the engine turns over but does not fire, all belts are ok even the timing belt. it didnt want to mess with it to much for fear of causing more issues. if anybody could give me some ideas where to start looking would be great, all of you guys have been good to me when i needed help so thanks much.
Old Dec 13, 2008 | 12:50 PM
cincyTT's Avatar
I'm make believe
I heard about you from your TT friend. There neglagents damaged your car and they need to fix everything they damaged
Old Dec 13, 2008 | 01:43 PM
FASTER's Avatar
Tech Slut
sounds like maybe the charge piping blew off... check all hose clamps between the compressor side of the turbo and the throttle body...
Old Dec 13, 2008 | 08:05 PM
ok ill have to take a second look at the charge tube when i tow it over to the shop tomorrow. thanks guys
Old Dec 14, 2008 | 12:37 AM
ghost6303's Avatar
if it was any intake pipe it would start, but it would just run like crap. start by making the shop fix it or pay to have it fixed elsewhere. scan for codes would be the first thing to do.
Old Dec 14, 2008 | 09:52 AM
well as soon as warms up a bit outside ill get it back over to the shop and go from there. i guess i should invest in VAG-COM so i can pretty much eliminate going to the shop. i also forgot to mention that what little i tried to start it (fear of something internal broken) it acted as though it had no compression. ill let you guys know more come monday night, thanks
Old Dec 14, 2008 | 09:40 PM
Audi_Skydiver's Avatar
Get a compression tester... That will tell you for sure.
josh
mmaker
Oct 3, 2013 11:05 PM
milan2k12
Apr 24, 2012 08:20 AM
pete7
Mar 11, 2008 03:04 PM
spawnywhippet
Nov 16, 2007 06:26 PM
cireecnop1
Dec 20, 2005 12:19 PM
