Coolant Problem.. HELP!!
Old 08-02-2009, 03:51 PM
Zipper's Avatar
Exclamation Coolant Problem.. HELP!!
So, it all started when I got a CEL for the Coolant Temp Sensor. So I changed it with a new green version. The light went away, but apparently I did something stupid with the sensor clip as it was not tightened properly. So when I took it out for a drive, the coolant started leaking.. vapor.. smoke etc.. Had to take everything apart and make sure the sensor was put in right. I then filled up the expansion tank with more coolant/distilled water until the max line and took it for a ride again.. The temp gauge was hitting high and once again the coolant in the expansion tank had dissapeared. I check for leaks, but couldn't find any.. no vapor, no smoke.. just the engine heating up and the coolant gone! Could it be that it needs more coolant?
I should mention that I also put in a RAM intake when I put the temp. sensor. I VAG'd the engine blocks 02/03 for the injectors/MAF etc and they all look fine, within the range.
Has anyone got any idea what's going on? I'll probably go get some more coolant tomorrow.
Boost Apostle
08-05-2009 04:01 PM
michaelh305
06-12-2008 05:27 PM
pv1127
07-24-2007 05:34 PM
solrac
07-16-2007 08:55 PM
Logik250
10-02-2006 10:15 PM
Quick Reply: Coolant Problem.. HELP!!
