Could this possibly throw a CEL?
Old Nov 19, 2008 | 01:28 PM
  #21
Jc61990's Avatar
yea i cleared them.. but no matter what every time i rescan my car even after i clear
2 Faults Found:
00532 - Supply Voltage B+
39-10 - Output won't Switch or Short to Ground - Intermittent
00526 - Brake Light Switch-F
27-00 - Implausible Signal
will always show up
Old Nov 19, 2008 | 01:47 PM
  #22
onepoint8tee's Avatar
2 Faults Found:
Which control module did this fault come up for? Could be multiple control modules.
00532 - Supply Voltage B+: Signal too Low
Possible Causes
Wiring/Connectors from/to Control Module faulty
Power Supply (Battery/Generator) faulty
Old Nov 19, 2008 | 02:27 PM
  #23
Jc61990's Avatar
i think the ABS module or the Auto Trans
Old Nov 19, 2008 | 02:39 PM
  #24
If it came up under ABS then the problem could be related to the brake light switch. If it's the tranny then I'm not sure what the problem could be if it's not the TCM. As long as everything seems ok then I'd say don't worry much about about it.
Old Nov 19, 2008 | 03:17 PM
  #25
Jc61990's Avatar
im almost positive it was under the Trans... ill scan it again now just to be sure. cause it always shows up
Old Nov 19, 2008 | 03:22 PM
  #26
Jc61990's Avatar
yup its the Auto Trans Module.. and i tried hitting the brake before i scanned, and the brake switch code didnt show up
Old Nov 19, 2008 | 03:27 PM
  #27
How long have you been getting the supply voltage code for?
Old Nov 19, 2008 | 03:29 PM
  #28
Jc61990's Avatar
since i got vag-com, i might have an idea of what it is. ill see if it fixes it when i take it out...
Old Nov 22, 2008 | 04:34 PM
  #29
Jc61990's Avatar
CEL came on this morning... scanned just now.. same exact codes as last time
Code:
VAG-COM Version: Release 409.1-S
Control Module Part Number: 8D0 907 557 P
  Component and/or Version: 1.8L R4/5VT MOTR AT D06
           Software Coding: 06251
            Work Shop Code: WSC 06335
3 Faults Found:
18032 - MIL Request Signal Active (Check TCM for errors too!)
        P1624 - 35-10 - - - Intermittent
16502 - Engine Coolant Temp. Sensor (G62): Signal too High
        P0118 - 35-10 - - - Intermittent
18021 - MIL Control Circuit: Open or Short to Plus
        P1613 - 35-10 - - - Intermittent
looks like ill put in the new ects, just not now.. its 20degrees out
zectasy
Jun 7, 2007 11:44 AM
Justin_72
May 3, 2007 01:43 PM
theTTkid
Mar 29, 2007 09:35 PM
n0dn4rb
Dec 19, 2006 08:51 AM
ZedEx
Dec 20, 2005 06:34 PM
