Crank is stuck, can't turn from crankshaft
Old Jan 20, 2013 | 12:57 AM
Boober's Avatar
Default Crank is stuck, can't turn from crankshaft
TB broke and I have to replace some valves... I used to be able to turn the crank with a ratchet by hand, but now it's stuck solid. The battery also died before the problem started.
Has anybody ever seen this before? Does it have to do with the battery dying?
thanks
Old Jan 20, 2013 | 01:04 AM
redline380's Avatar
Legal Moderator
nothing to do with battery. most likely the valves are very bent and have bound the crank by stopping the motion of the pistons. i want pics of the carnage when its pulled apart
Old Jan 20, 2013 | 08:58 AM
jonbonesjones's Avatar
Moderator
Your fucked sorry
Why exactly would you turn it knowing you have bent valves?
Old Jan 20, 2013 | 02:05 PM
Boober's Avatar
Timing belt only jumped a few teeth, reset the timing with a new belt to see if they were indeed bent. I agree that it probably is bent valves jamming the motion. Will have the time to fix it in about a month.
Trigger200
B7 Models
Apr 27, 2015 11:58 PM
Brad Kayak
Jul 7, 2014 12:53 PM
Boober
Mar 21, 2013 05:46 PM
noahjb
Jun 15, 2009 10:34 PM
