Fuel Pump pressure regulator
Old Apr 21, 2012 | 01:52 PM
Brochacho's Avatar
Default Fuel Pump pressure regulator
Hey Guys!
You have all been an awesome help with helping me fix my B5 up, but so much more to go =P. Now I'm looking for a part number for a fuel pump pressure regulator, if anyone happens to know a part number for it that would be amazing. Im also looking to replace the plastic piece that runs along the bottom of the windshield. Not exactly sure what its called, but its the piece that you can't remove unless you remove the wiper blades first. If anyone has any idea what I'm talking about, and has a part number or knows where to get it... I would really appreciate it! Thanks!
Old Apr 21, 2012 | 02:16 PM
MetalMan's Avatar
Fuel pressure regulator:
Audi B5 A4 Quattro 1.8T > Engine > Fuel > Pressure Regulator > ES#1073 Bosch OEM 4.0 Bar Fuel Pressure Regulator - 0280160575SJ
The other is called a water deflector. ECS Tuning doesn't list the facelift version (what you need) but here is the prefacelift version for reference:
OEM / Performance Parts for Audi, BMW, Mercedes Benz, Mini, Porsche & Volkswagen - ECS Tuning
Old Apr 21, 2012 | 04:21 PM
Brochacho's Avatar
Thanks for the links. How can you tell I have the facelift? What are the differences between the prefacelift and the facelift?
Old Apr 21, 2012 | 08:16 PM
MetalMan's Avatar
Your signature says you have a 2001. Facelift started 1999.5. There's a chart floating around somewhere, if I had more time I'd do a Google search for you.
Old Apr 21, 2012 | 09:48 PM
Brochacho's Avatar
Oh! I see what you are saying. I thought you meant there was a facelift like 2001.5 or something.
Old Apr 23, 2012 | 02:53 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
Fuel pressure regulator is 078-133-534-c for 135.00 and it's 3 days away to order in. The p/n's on the deflectors are 8D181940101C and 40201C for 56.25 each, both in stock. Thank you, Jeff.
Old Apr 23, 2012 | 03:14 PM
DanaB6's Avatar
on my 01 a4 the plastic water deflectors are easy to remove. you dont need to remove the windsheilf wipers. just remove the plastic that covers your battery area and turn the plastic bolts on the deflector and it.should slide out. when u remove it pull it to the side first because the 2 peices interlock. mine are both busted and in pretty bad shape. so i can just pull them out like that but i may be wrong..just my 2¢
mpeksd
Feb 25, 2014 09:20 AM
KinkySlayer
Nov 22, 2010 07:42 PM
kerNol
Feb 25, 2009 09:53 PM
Red_sapphire89
Feb 10, 2008 12:05 PM
saranaz
Nov 21, 2007 12:15 AM
