grinding in second
Old Apr 21, 2010 | 10:56 AM
y^0's Avatar
y^0
Default grinding in second
hey guys, i have a grinding noise when i have low rpm's in second gear (it goes away when i pass 2500 rpm's) there is not a cel or a code that states a problem, but i was just wondering if there was going to be a longterm negative affect or if there was a way to fix it. ideas?
Old Apr 21, 2010 | 12:59 PM
flynnr's Avatar
clutch chatter?
Old Apr 21, 2010 | 10:33 PM
Mike-2ptzero's Avatar
grinding noise when you are already in 2nd gear or when your shifting into 2nd?
Old Apr 21, 2010 | 11:25 PM
y^0's Avatar
y^0
it's when the car is IN second, and it is actually below what i said. it grinds under 1800 rpms.
Old Apr 22, 2010 | 10:04 AM
Is it an actual grinding noise(metal to metal) or are you hearing a vibration?
Old Apr 22, 2010 | 11:35 AM
y^0's Avatar
y^0
it definitely sounds more like a grinding noise than a vibration. the pitch goes up slightly as i accelerate if that makes any difference.
Old Apr 22, 2010 | 11:43 AM
Do you feel anything in the pedal when its making that noise?
Old Apr 22, 2010 | 11:27 PM
y^0's Avatar
y^0
no odd feeling in the pedal, and the best way to describe the noise is more of a shredding sound than a grinding one. it doesnt happen though if i accelerate slowly in second rather than at a normal or quick pace.
Old Apr 23, 2010 | 12:30 AM
Wow that would have to be a sound I would need to hear to figure out. Could be clutch, flywheel, transmission or even just the metal plate that goes between the block/bellhousing rubbing on the flywheel.
A4driver17
Jun 7, 2011 09:43 PM
DanDanUK
Feb 17, 2009 11:54 AM
acamillo
Oct 4, 2007 01:52 PM
krnaudi
Jul 20, 2007 03:44 PM
dubiousmusic
Sep 10, 2005 06:53 PM
