heating problem
Old Nov 1, 2010 | 12:18 PM
Sean2low's Avatar
Default heating problem
Hello everyone I'm new to the forum and i'm from montreal and I own a b5 2.8l quattro a4 with 245000km
I'm having problems with the heating in my a4, when I put the heating to the max I only get a little bit of hot air and my car does take some time for it to reach 90c on the temp gauge. what would be the cause of that?
thank you
Old Nov 1, 2010 | 02:26 PM
Msnickbroderick's Avatar
Actual WIZARD
Clogged heater core or bad thermostat, but probably the latter
Old Nov 1, 2010 | 03:55 PM
CCA4's Avatar
Originally Posted by Keegan0103
...or bad thermostat, but probably the latter
This. Let your car run for a while, pop the hood and feel the top radiator hose. If it's not uncomfortably hot to hold onto its not hot enough and your thermostat is stuck open.
Old Nov 1, 2010 | 04:07 PM
Sean2low's Avatar
where would this hose be? because i'm a noob and can't see it
Old Nov 1, 2010 | 05:52 PM
CCA4's Avatar
Circled in this pic:
Even if you don't have a 1.8T, it should be in a similar location on the V6
Old Nov 1, 2010 | 06:32 PM
Sean2low's Avatar
ok i'll go check it out, thanks I appreciate it
Old Nov 1, 2010 | 09:53 PM
ImTheDevil's Avatar
Agreed, and open thermostats are relatively common on 2.8L cars. Find the yellow funky shaped coolant tank with the blue cap. There's a small hose coming off the front. That little hose leads to the upper rad hose that CCA4 is talking about.
Old Nov 15, 2010 | 09:01 PM
Sean2low's Avatar
hey I just checked this out, let my car get to 90c before checking and the result was that it was hot but not uncomfortably hot so does this mean my thermostat is open? and if so how do I close it because it's starting to get cold up here in canada
Old Nov 16, 2010 | 10:17 AM
jdahlen24's Avatar
Does it give out good heat while driving at highway speeds? If not, it could be that your heater core is plugged.
Here's a great DIY article on how to flush it yourself. http://forums.audiworld.com/showthread.php?t=349252
Old Nov 16, 2010 | 10:38 AM
Sean2low's Avatar
it does give me heat but its not strong at all
DaveQ7
Audi Q7
Sep 16, 2014 01:58 PM
Julianpnc
Oct 23, 2012 04:15 PM
Paul Rasmussen
Oct 10, 2012 08:51 PM
plumbous
Dec 15, 2009 10:19 AM
jj2345
Aug 21, 2009 11:06 PM
