Help please! Cv joints
Old Jan 23, 2011 | 12:29 PM
dragonrage's Avatar
The inner should separate very easily, though the boot will need some convincing. When unbolted, use a chisel on the lip of the metal part of the boot and lightly tap it with a hammer to loosen it. I think it will probably be easier to replace the boot via removing the outer again. Just so you know, the inner boot kits you can order from ECS/whatever do come with a new axle bolt.
Old Jan 23, 2011 | 12:46 PM
fast euro's Avatar
Originally Posted by Devildub
You have to pull the outter out of the hub to get the inner out of the transmission and then fix/ replace with the whole shaft out of the car, what is what u shoud have done with the outter so as to not damage the inner. Carefully use a prybar to remove the inner from the transmission
Cool thanks
Clickyurdead
Oct 12, 2009 12:32 AM
1.8tee-time
Jun 25, 2009 03:42 AM
shady927
Oct 22, 2008 10:09 PM
TopGUn86
Aug 16, 2007 12:41 PM
blueaudi
May 31, 2005 02:54 PM
