How screwed am I?
again
coolant temp sensor - it cause rich starts. Try pushing the pedal all the way to the floor and crank it, this shuts off the injectors and should helop it start easier, release the pedal when it tries to start, you should know how your engine sounds.
The part is 15 bucks includes a new clip a new oring and a new sensor. DIY
Yup and make sure that a) you get the old o-ring out, and b) the sensor is clipped in properly. Either of these will allow all your coolant to blow out if not done right. Scale of 1-10, it's a 1 to DIY - no harder than changing the oil.
