low and high revs at idle?
Old Feb 26, 2013 | 08:16 PM
moneyfresh's Avatar
Default low and high revs at idle?
hey just replaced my valve cover gasket today, install was smooth, while i was there i decided to also do a compression test, i got about 180-190psi on all cylinders, but now i have this weird rev at idle, took it for a good spin, came home and let it idle for turbo to cool. and it would idle normal at 800 then every 15-20 seconds rev to 1000 for a second and back to 800, it repeats this inf. amount of times.
now, when moving spark plugs i dropped 2 of them twice... and my secondary air pump is shot, makes the loud winding noise at cold start up for a few minutes then stops, (also would the SAP delete be worth my time?)
vag-com says normal faults, oxygen sensors
any help would be great, thanks!
1.8t atw quattro a4
Old Feb 26, 2013 | 11:41 PM
markymarc's Avatar
Did you put everything back the way it was?
Is it something like this video?
Old Feb 27, 2013 | 05:53 AM
moneyfresh's Avatar
VW G62 sensor problem - YouTube
everything went together the same way it came off, and no not at all, ill get a video if it continues. thanks for reply!
docinanaudi
Aug 9, 2011 05:20 PM
ccie13269
Mar 26, 2010 01:05 PM
Pabl0
Mar 10, 2010 09:34 PM
flynby
Nov 13, 2007 09:55 PM
pciguru
Oct 23, 2004 02:58 PM
