New codes found after vag-com scan =x
Old Mar 26, 2011 | 08:36 PM
morpheous's Avatar
Unhappy New codes found after vag-com scan =x
I came across some new codes,was wondering what could have caused them.
VAG-COM Version: Release 311.2-N
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01 -------------------------------------------------------
Controller: 4B0 906 018 CH
Component: 1.8L R4/5VT G 0001
Coding: 16251
Shop #: WSC 63351
4 Faults Found:
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 35-10 - - - Intermittent
16795 - Secondary Air Injection System: Incorrect Flow Detected
P0411 - 35-00 - -
18032 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 02 -------------------------------------------------------
Controller: 8D0 927 156 DF
Component: AG5 01V 1.8l5VT USA 1010
Coding: 00002
Shop #: WSC 06435
1 Fault Found:
17114 - Incorrect Gear Ratio
P0730 - 35-10 - - - Intermittent
Address 03 -------------------------------------------------------
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
No fault code found.
Address 08 -------------------------------------------------------
Controller: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00140
Shop #: WSC 63351
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D12
Coding: 02444
Shop #: WSC 19411
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 63351
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
End -------------------------------------------------------
Old Mar 28, 2011 | 03:22 AM
Cristisor's Avatar
First of all, in order to make sure that these are not old codes, delete them and then go for a ride and make a new scan after.
This is what Ross-Tech says:
Possible Causes
* Fuse(s) faulty
o if the blade wheel (rotor) in the vacuum pump is stuck, most probably a fuse will burn
* Hoses from/to Brake Boost Vacuum Pump faulty
* Brake Boost Vacuum Pump faulty
o the blade wheel (rotor) in the vacuum pump is stuck
Check the vacuum lines near the brake booster or for other obvious issues you may see there.
Someone, on another forum, says: "The servo vac pipe has a t piece with one way valve. Check the one way valve by blowing and sucking. It is designed to maintain vacuum so you should be able to suck from the servo end but not blow."
There is a chance you might have a vacuum leak in the secondary air pump system. Check the hoses that are around the secondary air system.
Possible Causes
* Fault Codes stored in Transmission Control Module
You should check for error codes in other modules.
Can't help you on that.
Old Mar 28, 2011 | 11:45 AM
morpheous's Avatar
Possible Causes
* Fuse(s) faulty
Possible Causes
I cleared all the codes and only this came back:
The TCM gave off the "incorrect gear ratio" before i got my tranny replaced,would'nt go into forth gear as it would kick bakck down to 3rd,so that didn't come back either.
These vacuum lines,isn't there 4 on the 1.8T ? if so,could someone post a picture of all 4 lines,that i need to inspect for holes and damage,please???
what i need is some sort of legend,that shows the entire engine bay,with arrows pointing to each component,with its name high lighted,so i know what part is what from that point on,anyone have such a chart or legend that i can be linked too?
Thanks for responding friend
Old Mar 28, 2011 | 08:25 PM
morpheous's Avatar
anyone have a link for the bentley book in pdf format?
Old Mar 29, 2011 | 12:40 AM
morpheous's Avatar
anyone??
Old Mar 29, 2011 | 02:09 AM
Cristisor's Avatar
You're welcome buddy. For as long as I know the 1.8t engine has 4 vacuum lines, but I don't have a picture with the engine, sorry.
If you find a Bentley book in pdf format please let me know.
Thanks.
Old Mar 29, 2011 | 03:33 AM
Andrew149's Avatar
Stickies
Old Mar 29, 2011 | 01:44 PM
morpheous's Avatar
lemme take a quick peek
Old Mar 30, 2011 | 01:13 AM
Cristisor's Avatar
Any luck, morpheous? I couldn't find it
Old Apr 5, 2011 | 12:57 PM
morpheous's Avatar
Yes,i found the Bentley pdf,under the "f.a.q" sticky,labeled "B5 Assembly Manual and Torque Specs" download the zip,extract and open with acrobat reader.
californiadaddy
Oct 27, 2013 09:13 PM
immusicman
Oct 1, 2010 01:27 AM
drs2000rr
Nov 10, 2009 11:37 AM
B5Bobby
Aug 30, 2009 06:14 PM
DEDMN_TT
Nov 18, 2007 04:31 PM
