Squeak Squeak Help Help
Old 05-14-2008, 10:45 AM
Mathis147's Avatar
Default Squeak Squeak Help Help
So I took a 800 mile road trip yesterday to get my boy from college, all is well with the car except when I was coming down the mountain, speeds moderately high, I started to notice a squeaking noise coming from the front right of the car. When I got to his school, anytime you push down on the car, turn the wheel, or hit bumps, it squeaks. When i looked underneath the car the only thing different on the right side from the left is that the boot that covers the ball and socket joint thingie near the top of the wheel wellhas been ripped and is now seperated from the end but its the part near the top with the flexi-boot covering it. Could this be it, and the joint is just dirty, or more serious problems probably lurking undernaeath? thanks
Old 05-14-2008, 11:39 AM
hiwords's Avatar
Default RE: Squeak Squeak Help Help
that's your control arm and with the boot ripped, you'll need to replace it. you see the huge bolt that goes across the 2 controls that are above the wheel? that's called the pinch bolt AKA the shittiest designed bolt ever. you might have a hard time getting that SOB out. check your other control arms too but grabbing them and wiggling, if they feel rly loose, you should replace all of them since you got the pinch bolt apart anyways. ebay controls arm the cheapest you'll find and i've have mine for a year and they are great.
Old 05-14-2008, 12:02 PM
jago's Avatar
control arms. look around online for them ecstunning has a set of 8 for like 530$ the dealer ship will rape you for 522$ for only four of them ( four arms in front and four in the rear)
Old 05-14-2008, 01:06 PM
hiwords's Avatar
no there's 8 in the front, 2 upper and 2 lower
Old 05-14-2008, 07:42 PM
control arms, whatever suck, I've replaced them twice on my 1999 and they need it again. Ugh!!!
Old 05-14-2008, 07:47 PM
hiwords's Avatar
if it's squeaking again, just get a grease gun, high temp grease and a grease gun needle. put the needle on the gun and the grease in it and put a little bit of grease into each boot. don't pump too much in because the boot will explode
Old 05-14-2008, 08:11 PM
InfamousA4's Avatar
Sorry to thread jack, but I have a similar problem that may be a common one. I have the squeaking coming from the front drivers side, it only starts up at about 35-40 mph. At first I thought it was the wheel bearing but after changing it out, it still happens...so I change outthe front brakes...still squeaking...
Old 05-15-2008, 01:04 AM
Mathis147's Avatar
it was definetely coming from the exposed joint that was previously covered by the boot, I cleaned her out at applied high temp grease right after i posted and that has almost entirely made the noise go away, either case will have to find a way to re-attach the boot or completely replace in the near future.
Old 05-19-2008, 01:58 PM
jago's Avatar
ORIGINAL: hiwords
oh wow my baad. **please dont flame**
Old 05-19-2008, 04:57 PM
brrman's Avatar
I wrote this for the DIY-techsection quite a while ago...
https://www.audiforums.com/m_37829/tm.htm
Pjbrof
08-05-2009 11:44 PM
ron86toy
06-04-2009 05:14 PM
marcb0127t
02-07-2009 07:55 PM
Trey25
07-28-2006 01:22 PM
impaler2383
06-20-2006 12:10 AM
Quick Reply: Squeak Squeak Help Help
