Strange Coolant Temp Problem
Old Nov 27, 2011 | 11:55 AM
bshusted's Avatar
Default Strange Coolant Temp Problem
I've been having issues with the temp gauge reading all over the place and decided that the ECT was to blame. I took care of that and then went for a drive to test it out.
On the initial drive, things went as expected. The engine warmed up and the needle climbed to the halfway mark and stayed there for a while. I had heat in the cabin, which was never a problem before. Here's the weird part. Then the gauge proceeded to go all the way back down to one mark above cold. Heat in the cabin is still good.
I originally ruled out the thermostat since I always had heat and the temp didn't seem to fluctuate with moving or stopped at a light. What's my next move?
Old Nov 27, 2011 | 01:03 PM
jonbonesjones's Avatar
Moderator
when you turn the heat on it should drop the gauge. Im not sure if it should go back that much tho?
Old Nov 27, 2011 | 04:29 PM
bshusted's Avatar
Heat on or off didn't seem to affect the gauge reading . This is really frustrating.
Old Nov 27, 2011 | 06:22 PM
ImTheDevil's Avatar
Heater on/off has never affected my gauge.
Old Nov 27, 2011 | 09:00 PM
02audia6mann's Avatar
try replacing coolant temp sensor mine did this also ,,sensor fixed it
Old Nov 27, 2011 | 09:24 PM
redmond1501's Avatar
Replacing the coolant temp sensor corrected this issue for me. There are a couple different type sensors (indicated by their cap colors). Make sure you got the right type.
Old Nov 27, 2011 | 09:26 PM
bshusted's Avatar
I replaced the sensor as previously mentioned because I thought that it would solve the problem. All of the symptoms seemed to indicate that everything was working fine aside from the sensor.
There is the possibility that I received a "new" bad sensor. I assume that the sensor is just a thermistor should be able to test it by monitoring resistance at various temps. I suppose that there is some diagnostic I could do if I had VAG-COM.
Any other thoughts?
reziarfg
Apr 8, 2014 06:55 AM
JonSoyBoy
Jul 10, 2008 08:41 AM
Greenrino
Jan 4, 2008 10:37 AM
kx_rider53
Nov 25, 2007 09:09 PM
xx18quattroxx
Mar 30, 2006 11:44 AM
