Sunroof not moving correctly
Old 06-05-2010, 11:40 AM
vtraudt's Avatar
Default Sunroof not moving correctly
My problem on the 1998 Audi A4 (exactly the same problem I had with the with my 1994 Audi 100, same index switch):
The sunfroof is not moving into the correct position (for example: closed)
Putting the index switch (position selector on the roof panel) into slightly different position than you really want CAN get it to the desired (for example: closed) position. If often requires to select a position BEYOND the actual one.
From the Audi 100 I remember that knocking against the switch also sometime moved it to the position.
So in my case, I would clearly point at the index selector switch.
Are there any positioning sensor in the rails to tell the system what position the sunroof is in? Or is the positioning done by poti with position read out on the motor that moves the roof?
Anyone have a fix for it (from similar problem)?
Old 06-05-2010, 12:40 PM
Skythe's Avatar
I think most sunroof problems are either it opening randomly or it not closing all the way due to the track guides breaking.
I never saw a positioning sensor in the guides when I looked at mine; only pieces of plastic in the way
Try this
https://www.audiforums.com/forum/sho...unique+sunroof
Old 06-05-2010, 01:15 PM
vtraudt's Avatar
Skuthe, thanks for your input.
Further checking with son #1 reveals: it IS in deed RANDOM opening!!!
What now?
Old 06-05-2010, 02:27 PM
Skythe's Avatar
Try this fix
http://www.passatworld.com/forums/sh...d.php?t=238398
Everything should be the same
Big g man
11-06-2011 05:43 AM
ml3on21
03-04-2011 10:25 AM
Stearnsy
10-13-2007 12:08 PM
lewishw
02-16-2006 07:34 PM
EvilA4
08-17-2005 02:18 AM
Quick Reply: Sunroof not moving correctly
