Is there a way to turn the ABS light off?
Old Dec 1, 2009 | 12:29 PM
cruciform's Avatar
Default Is there a way to turn the ABS light off?
My control module is bad, as well as a couple of the ABS sensors. I dislike ABS anyway, so short of replacing the module and the sensors, is there a way to trick the ECU into thinking all is fine and dandy? all I desire is to have the pesky flashing light turned off..the brakes work fine otherwise...
The car is a 98 v6 5speed.
thanks!
Old Dec 1, 2009 | 05:05 PM
bradtyler02's Avatar
Tear the dash apart and take the bulb out? Just a thought...
Old Dec 3, 2009 | 11:46 AM
dlcain's Avatar
Not to change the subject, but will the ABS light go off by itself once the problem is fixed, or do you have to reset something? I think I might of messed up my abs sensor during my wheel bearing change. my ABS & Brake light are on steady (no flashing).
Old Dec 3, 2009 | 03:21 PM
tboner3's Avatar
Member
there is a thread on here where some guy found a way to turn it off by i believe bending the sensor? i'll try and find it if you don't get there first
Old Dec 3, 2009 | 07:29 PM
hiwords's Avatar
vag com can turn it off. don't try the bending sensor unless you know which one is broken and you can take it out.
Old Dec 3, 2009 | 09:18 PM
Cris_A's Avatar
Originally Posted by hiwords
vag com can turn it off. .
Sorry but what's vag com?
A4Boost
B7 Models
Feb 8, 2014 09:39 AM
vivanov1
Jul 15, 2013 11:35 AM
Sp33d07
Jun 4, 2006 02:32 PM
n18
Oct 3, 2005 07:32 PM
paliracer
Feb 21, 2005 03:15 PM
