Is there a way to turn the ABS light off?
My control module is bad, as well as a couple of the ABS sensors. I dislike ABS anyway, so short of replacing the module and the sensors, is there a way to trick the ECU into thinking all is fine and dandy? all I desire is to have the pesky flashing light turned off..the brakes work fine otherwise...
The car is a 98 v6 5speed.
thanks!
thanks!
Not to change the subject, but will the ABS light go off by itself once the problem is fixed, or do you have to reset something? I think I might of messed up my abs sensor during my wheel bearing change. my ABS & Brake light are on steady (no flashing).
