ESP Light Won't Turn Off
Old Mar 29, 2011 | 07:48 PM
A4Boost's Avatar
Default ESP Light Won't Turn Off
Hey Everyone,
It's been awhile since I have been on the forums and it's good to be back. This question is actually concerning my dad's 2005.5 A4 2.0TQ Auto. He just put a brand new set of 235/45 ZR17 tires on the car today and all of the sudden, the ESP light came on and he can't shut it off. I searched on the forums before I posted, did not come up with much. I was hoping that someone has had experience with this before and could offer some help. Thanks in advance for your help.
A4Boost
Old Mar 29, 2011 | 08:43 PM
Audi Tek's Avatar
Tech Certified
Did it comes on as soon as he started the car...?
Or driving awhile....?
Make sure the speed rating and load rating are the same for all 4 tires.
Old Mar 29, 2011 | 09:07 PM
A4Boost's Avatar
Hello Audi Tek,
Thank you for your quick response, I really appreciate it. I know that all of the tires are identical (Brand, Speed & Load ratings) but I am not sure if the light came on when he started the car or after he had been driving for awhile. He just told me that he could not turn it off using the button on the dash. Would these 2 conditions lead to a different diagnosis of the problem? Thanks again for your help.
A4Boost
Old Apr 1, 2011 | 05:53 PM
A4Boost's Avatar
Hello Everyone,
*Update* I spoke with my dad this afternoon and he told me that the ESP light came on, on it's own while he was driving and not right when he started the car. I am hoping that this information might help in diagnosing the problem. Thank you all for your help in advance.
A4Boost
Old Apr 1, 2011 | 08:13 PM
Audi Tek's Avatar
Tech Certified
its probably a faulty brake light switch then. You'd have to scan the brake module to be sure.
Old Apr 1, 2011 | 11:37 PM
A4Boost's Avatar
Hello Audi Tek,
Thanks for your help, it is greatly appreciated. If it were a faulty brake light switch, would any of the brake lights be out as a result? What would be your diagnosis if the ESP light had come on upon start up? I only ask because my dad seemed a little unsure if the light came on while he was already driving or if it had turned on when he started the car.
Thanks Again,
A4Boost
Old May 29, 2011 | 12:33 PM
youngm911's Avatar
Did you ever figure out this problem?
My ESP light comes on after I've been driving a while (2006 A4 Quattro), it only happens if I've been driving for a while over 50 or 60 mph.
Old Nov 30, 2013 | 10:53 AM
david.m.brigham's Avatar
Was this problem ever resolved? I have a 2005.5 A4 3.2 with the same problem.
Old Feb 8, 2014 | 09:39 AM
trizos's Avatar
hey guys. i have had the same issue for the past few days with my 2003 a4 1.8t
maybe you already did (or maybe they changed it now), but i read the car manual about the esp light. it says that if the light does not stop illuminating after starting your car, then there's probably a fault with the esp, or even with other brake related functions (such as the ABS) since all of these work together. in case the light comes up while you're driving, it means that for some reason the system deactivated esp, and you can turn it back on if you stop and restart your car.
hope this helps in some way
vivanov1
Jul 15, 2013 11:35 AM
cruciform
Dec 3, 2009 09:18 PM
Sp33d07
Jun 4, 2006 02:32 PM
n18
Oct 3, 2005 07:32 PM
paliracer
Feb 21, 2005 03:15 PM
