Vag-Com not working help.
Old Aug 18, 2009 | 02:12 PM
rplets15's Avatar
Default Vag-Com not working help.
I just got my Vag-Com cable yesterday and downloaded the software and everything and when i go to do a scan or anything it just pops up saying Vag-com has stopped working and shuts it down. Anyone know whats going on and how i can fix this??
Old Aug 18, 2009 | 02:43 PM
rcheing's Avatar
Post a screenshot, I work in desktop support and the exact error message helps tremendously in finding what the issue is. Also, make sure your cable shows up as a Serial Port under Device Manager. Furthermore, it is helpful to know what version of Vag-Com you are running, where you purchased your cable (some sellers include troubleshooting) and most importantly, what operating system is on your computer.
Old Aug 18, 2009 | 02:51 PM
rplets15's Avatar
I got the cable from alpha-bid on his website my os is vista the version of vag-com is the 406.1 i currently dont have a camera to tak a pic of of it but it says that windows has encountered a problem with the program and has to shut it down
Old Aug 18, 2009 | 02:59 PM
rcheing's Avatar
Exactly when does it error out? When you are scanning for codes or as soon as you open vagcom? Also under options where you able to test the interface ok?
That's a Windows Vista error message and not a Vag-Com error. You are probably running the program as a regular user. Where did you install to? The C:\Vag-Com or the C:\Program Files\Vag-Com path? Right click on the shortcut and go to properties, make sure under the compability tab to run the program in Windows XP SP2 or SP3 compability and check the box to run as Administrator. Also, there should be an advanced button somewhere on the first or second tab and make sure run as administrator is checked.
To do a screen print press the "Print Screen" button on your keyboard, then click on start, type "mspaint" and when Paint opens up click on Edit Paste and then save.
Old Aug 18, 2009 | 03:15 PM
rplets15's Avatar
ok so its been saved under C:\Program Files\Vag-Com I also went under the short cut and did what u said telling it to run compatible to windows xp sp2 and checked the run as administrator box.
Old Aug 18, 2009 | 03:18 PM
rplets15's Avatar
Oh My God thank you a bunch man its working now!!
Old Aug 18, 2009 | 03:31 PM
rcheing's Avatar
Thumbs up
Not a problem buddy! Glad it worked for you.
toolagit2qwit
Jan 27, 2014 10:32 AM
azzy28
Jan 29, 2012 11:03 AM
04ultrasprt
Oct 31, 2008 10:35 AM
austindgarner
Jun 23, 2008 09:31 PM
Retard Riot 686
Jun 11, 2008 10:32 PM
