Key fob not working
Old Dec 10, 2013 | 12:38 AM
toolagit2qwit's Avatar
Default Key fob not working
Hello. 1999 A6. So both fobs do not work. Replaced batteries and reprogrammed. Also. Purchased a new factory fob and same issue. History- fob one day did not work. I reprogrammed and it worked. Then it just stopped next day and not responding to programming. I checked the comfort control module located under driver footwell. No moisture or pins lose. Fuses check out fine.
Any other recommendations? Is there a relay or fuse under the dash or engine compartment i missed. All functions work with key in door lock. Alarm is armed when locked manually, windows close and open with key. Everything in car functions except the remote fob.
Thanks for you time!
Old Jan 27, 2014 | 10:32 AM
Audi dealer discovered this was not working due to headlight wireharness short- see link for details: note: Audi had an open recall in 2006 for this: https://www.audiforums.com/forum/aud...-cabin-203934/
azzy28
Jan 29, 2012 11:03 AM
Nellyuk
Nov 5, 2011 12:48 PM
04ultrasprt
Oct 31, 2008 10:35 AM
austindgarner
Jun 23, 2008 09:31 PM
Retard Riot 686
Jun 11, 2008 10:32 PM
