Whats the factory rev limiter set at?
Old Nov 3, 2010 | 02:24 PM
Msnickbroderick's Avatar
Actual WIZARD
Default Whats the factory rev limiter set at?
I was free revving my car after clearing codes to get them to show back up, and I definitely got about 3 lines into the red (which frankly scared me shitless) because thats how I spun a rod on my camry. So does anyone know exactly where the fuel cut is?
Old Nov 3, 2010 | 03:31 PM
Mike-2ptzero's Avatar
There is no rev limiter when there is no load on the motor. So if you free rev the car or miss a shift and go WOT you can take the car well beyond 8k rpm.
Stock rev limiter is 6700 rpm and chipped tends to be 7k-7200.
Old Nov 3, 2010 | 03:58 PM
kayakman13's Avatar
Is this because there is less danger in overrevving without load?
Old Nov 3, 2010 | 04:01 PM
I guess so. But that doesn't mean you wont cause damage since the valves can flow when revved over 8k.
Old Nov 3, 2010 | 04:10 PM
kayakman13's Avatar
And what's the danger of a floated valve? I know its not good for it, but I thought it would just not run as well.
Old Nov 3, 2010 | 04:47 PM
Bent valves and tattoo'd piston tops.
Old Nov 3, 2010 | 05:04 PM
Actual WIZARD
Who thought that would be a good idea? if you rev high enough say a missed 2 > 1 instead of 2 > 3, I know you can crack pistons, and possibly snap a rod. Bent valves obviously
Old Nov 3, 2010 | 10:35 PM
bradtyler02's Avatar
drive more carefuller
cmk87
Oct 12, 2007 02:18 PM
Obsessed
May 31, 2007 11:59 AM
falcompsx
May 29, 2007 03:05 AM
corvetteauto
Apr 6, 2007 03:40 AM
xx18quattroxx
Mar 15, 2006 08:41 PM
