Wont Shift Right....PLEASE HELP
Old Mar 2, 2012 | 07:13 PM
HomeboiiMech's Avatar
Post Wont Shift Right....PLEASE HELP
I got an 01 A4 1.8. She wont shift correctly. If i start her in nuetral she wont go into gear. When i start in 1st then i can shift that the way to 5th but cannot shift down. To get into reverse i have to turn her off n start in reverse.
I had a brand new clutch master and clutch slave from the previous owner so i installed it hopefulli that would fix it but no go. I dont believe it is the clutch because when i do start it and it is in gear if i release the clutch it will stall. It will stall in each gear. So from what i was taught the clutch is still good or at least wrking. Any ideas. Please guys this is my baby lol
Old Mar 2, 2012 | 09:30 PM
ImTheDevil's Avatar
Are you sure you bled the system properly? Did you do a bench bleed on the master before installing it?
Old Mar 7, 2012 | 08:32 AM
yea i did do that and also bleed the stlave when i installed it because the clutch felt like it wasnt holding pressure but after bleeding the slave it solved that issue. But still wont let me shift gears
Old Mar 7, 2012 | 09:31 AM
M5S5's Avatar
Tech Certified
Pressure plate probably took a dump. Keeps the clutch disc partially enguaged due to weak fingers.
slolatino
B7 Models
18
Feb 23, 2015 10:59 AM
kingen502
Oct 3, 2013 03:10 PM
HomeboiiMech
Feb 13, 2012 12:43 PM
SaintsRow
Jun 11, 2011 06:19 PM
ericp1.8T
Mar 26, 2010 07:59 AM
