clutch problem
Old Feb 20, 2013 | 10:52 PM
jbeanz978's Avatar
Default clutch problem
I ordered a oem replacment from advance autoparts the disk is unsprung i also have a stage 2 unsprung should i use one of these?
Old Feb 20, 2013 | 10:54 PM
jbeanz978's Avatar
Oh ya im planing on apr 1+ tune and supporting mods in the next two months
Old Feb 20, 2013 | 11:52 PM
redline380's Avatar
Legal Moderator
unpsrung wont matter much as you have a dual mass flywheel. it is meant to aborb the vibraton instead of the disk itself. feel free to use either, but i would use oem, unless your stage 2 is a brand name like sachs. if its ebay, id pass
Old Feb 21, 2013 | 08:19 AM
jbeanz978's Avatar
Sweet
Old Feb 21, 2013 | 08:22 AM
jbeanz978's Avatar
Thanks for the info i thought the same i just wanted to be sure im going with the oem the stage two feels very cheap on the friction disk compared to the oem. Thanks for the reply.
Old Feb 21, 2013 | 01:05 PM
redline380's Avatar
Legal Moderator
no problem
Old Feb 23, 2013 | 11:11 PM
Mike-2ptzero's Avatar
Not a good idea to throw a different disk in with the stock pressure plate since the disk could be of a different thickness. If it is too thin the PP might not clamp down on it enough and ending up with less clamping load and even a shorter life span. If it is too thick the disk might not release completely causing problems of getting into gear.
ikkezelf
Jan 31, 2008 06:54 AM
beetee
Jun 1, 2007 06:18 AM
Matt_Iliketurbopull
May 1, 2007 05:28 PM
Matt_Iliketurbopull
Apr 28, 2007 03:06 PM
dane
Mar 3, 2005 07:25 PM
