fault codes.
2002, v6, petrol, a4 cabriolet.
Hi, my engine managment light has couple
of times and wanted to know how to solve the problems that have shown up on the scan i did.
I have read threads on the forum about the clutch pedal problem but needed advise on the others please.
5 Faults Found:
17947 - Clutch Pedal Switch (F36)
P1539 - 004 - Implausible Signal
17831 - Secondary Air Injection System; Bank 1
P1423 - 002 - Insufficient Flow - MIL ON
17819 - Secondary Air Injection System; Bank 2
P1411 - 002 - Insufficient Flow - MIL ON
18010 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
16890 - Idle Control System
P0506 - 002 - RPM Lower than Expected - Intermittent
When i disconect the battery to reset and scan again none of the above show up but a different one.
1 Fault Found:
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
Any help would be great.
Thanks.
5 Faults Found:
1 Fault Found:
Thanks.
First off disconnecting the battery does not fix any problem the car has. It just makes the check engine light go out until the car runs the monitors again & discovers the problem again.
What are the complaints that you are trying to resolve?
From what i see you have a problem with the secondary air injection system that will make the check engine light go on , other than that do not look for problem unless you have a complaint!
