FMIC ?
Old Jun 9, 2008 | 08:25 PM
  #21
audiprotein's Avatar
Default RE: FMIC ?
Install process should be the same... But fitment is where the probelm.
Old Jun 9, 2008 | 10:57 PM
  #22
bustanut's Avatar
Default RE: FMIC ?
Racetec fits, but it's tight. No cutting of anything to fit. Everyone posts at least one "It won't fit, are these parts right" post after first trying install. And we all assure them it does and they are the right parts. It's tricky, but it works and you have to cut nothing.
Old Jun 10, 2008 | 02:14 AM
  #23
14psi's Avatar
Member
Default RE: FMIC ?
Thats what I mean.. How's the fitment on them? Have to relocate stuff? Cut stuff?
Old Jun 10, 2008 | 09:57 AM
  #24
bustanut's Avatar
Default RE: FMIC ?
My SAI pump needed bent up a little (the bracket that holds it) and of course your power steering cooler tube needs bent out of the way (as with most of the FMIC's, but ER COMP comes with a separate powersteering cooler, NICE!).
Other than that, everything is tight but fits fine with no modifications for the Racetec. But on initial try, of course because people are so anxious to get it in and don't take their time, everyone thinks it won't fit and posts on the forums thinking they got the wrong parts.
You won't find any FMIC that is big enough to hendle larger turbos that isn't a tight squeeze. Trade off- if the FMIC fits easily, it probably isn't good enough to work for larger turbo.
Old Jun 10, 2008 | 10:30 AM
  #25
Papachristou's Avatar
Default RE: FMIC ?
if you arent going BT, there is no need for the ER comp, thats way overkill... they have a smaller one, ER sport... racetec is the best bang for ur buck though... mine fit no problems.. didnt trim the bumper or anything.. i did buy a hayden tranny cooler 4x8 and used that for my power steering cooler (mounted it above racetec) there are some pics in my gallery)
the hotside piping took me a few minutes to figure out, i have some pics of that if u need too, just PM me
Old Jun 10, 2008 | 11:43 AM
  #26
14psi's Avatar
Member
Default RE: FMIC ?
I'm going BT within the next year. But thanks for you help everyone!
kpan
Oct 19, 2009 09:54 PM
Reiem125
Nov 5, 2007 08:51 AM
DurTTy
Aug 7, 2007 12:20 PM
6g72tt
Apr 30, 2007 10:28 AM
sooks
Apr 2, 2007 01:48 AM
