Water caused electrical problem
Old Dec 23, 2010 | 10:57 AM
sasuga's Avatar
Default Water caused electrical problem
2005 A4 AVANT 1.8 LITER QUATTRO. Street where I parked my car overflowed from heavy rain yesterday with water rising to my axels. I was alerted to the problem when my neighbor told me my car alarm went off and the water was rising. Luckily the rain subsided and I was able to move the car to higher ground. However, now my alarm system no longer works, along with the inside lighting, power windows, and power sunroof. Other than those problems everything else seems to be okay (I hope.).
Before taking the car in for, most likely, expensive repair, I thought I'd ask the experts in the forum.
Any help would be highly appreciated.
Wishing everyone a Merry Christmas.
Old Dec 23, 2010 | 12:56 PM
A4inMaui's Avatar
bummer. I wish I knew of the specific modules of that car that may have gotten flooded but I don't. If you can get under there you may be able to see some or even a ground location that you could take off and clean.
I would also check in other areas such as behind dash, below windshield area and see of they got wet. That is most likely where a module would be of the things are don't work. Also of course check fuses.
If you find a module or relay you can take it out and blow dry it or stick it in a bag of rice for awhile to have the rice pul moisture out
Good luck.
Old Dec 23, 2010 | 01:42 PM
sasuga's Avatar
Thank you for the info. I will check the fuses if I can find them. I can't get under the car and even if I could, I wouldn't know what to look for. Do you think disconnecting the battery and reconnecting it would help. By the way, no water got inside the car.
Old Dec 24, 2010 | 02:02 AM
A4inMaui's Avatar
yes, good suggestion to disconnect and wait. Sometime circuits need to reset and in this case, maybe dry out.
Old Dec 24, 2010 | 12:52 PM
B964's Avatar
Comfort control module?
Mounted in a box under the carpet in front of drivers seat.
Controls inside lighting, power windows, sunroof and some other components. Not a work today but somewhere around $300.00 plus install and set up.
Old Dec 25, 2010 | 10:27 AM
sasuga's Avatar
Thank you both for the information. I disconnected and reconnected the battery with good results--everything works now except the alarm system. Does anyone know how to reset it?
Old Dec 27, 2010 | 12:48 PM
Audi Tek's Avatar
Tech Certified
Your comfort control module is most likely shorted out.
Old Dec 27, 2010 | 03:19 PM
pa4ul's Avatar
x2 ^ Search ebay or classifieds. Their always up for grabs way cheaper then the stearlership.
1999jayman
Aug 12, 2014 12:43 PM
patc890
Jan 17, 2010 10:31 AM
BMF!
Jan 24, 2009 12:23 PM
