wondering bout intake install!
Old Sep 4, 2008 | 05:19 PM
gmfrosto's Avatar
Default wondering bout intake install!
i just got my new intake in the mail.
im sure its pretty simple
but i dont wanna screw up on install.
anyone got some instructions?
Old Sep 4, 2008 | 05:35 PM
Marine702's Avatar
What type of intake do you have? I got one from AFE. I looks, sounds and performs great! It even uses the factory fresh air scoop to draw air in. If your AIT has a MAF sensor port I can probably help you out, I have some directions that I got with my AIT.
Old Sep 4, 2008 | 05:46 PM
gmfrosto's Avatar
short ram intake system from maxspeed motorsports.
Old Sep 4, 2008 | 06:06 PM
gmfrosto's Avatar
so i figured it out. but im stuck on taking the MAF off. the screws are some weird type, that i dont have the driver too. anyone know what there called so i can go get one
Old Sep 5, 2008 | 04:38 AM
Marine702's Avatar
Yeah, hey I called a performance shop here in VA and they said to use those flat head screw drivers, you know like the ones they give out during promotions. The ones about the size of a flathead screw driver from a reading glasses repair kit. All you need to do is firmly wedge it between the points of the of the screw and turn, they come out really easy.
Old Sep 5, 2008 | 03:15 PM
cantdrive55's Avatar
It's a security bolt so not every joe-blow takes it apart. You might be able to get it out with the idea above but otherwise try a local autoparts store and see if they have one. Or you could gently dremel out the head to make it so it accepts just a normal flat head.
Old Sep 6, 2008 | 04:10 AM
Marine702's Avatar
Negative! I called eight car parts stores around here and they told me that there isnt an "inverted Torx screwdriver" to unscrew it. Just go ahead and do it my way.
Old Sep 7, 2008 | 05:38 AM
Sublime865's Avatar
I don't remember that on my Carbonio install, but I remember using the housing from stock if I recall. Seems odd.
zaboomafoo1212
May 31, 2013 09:51 AM
akrcoceo
Dec 6, 2008 07:17 PM
cstower
Apr 5, 2007 12:45 AM
edkwok
Nov 23, 2006 03:51 AM
GeoRay16
Oct 19, 2006 02:40 AM
