wondering bout intake install!
What type of intake do you have? I got one from AFE. I looks, sounds and performs great! It even uses the factory fresh air scoop to draw air in. If your AIT has a MAF sensor port I can probably help you out, I have some directions that I got with my AIT.
Yeah, hey I called a performance shop here in VA and they said to use those flat head screw drivers, you know like the ones they give out during promotions. The ones about the size of a flathead screw driver from a reading glasses repair kit. All you need to do is firmly wedge it between the points of the of the screw and turn, they come out really easy.
It's a security bolt so not every joe-blow takes it apart. You might be able to get it out with the idea above but otherwise try a local autoparts store and see if they have one. Or you could gently dremel out the head to make it so it accepts just a normal flat head.
