Misfire DTCs after dealer TSB
Old May 1, 2011 | 01:47 PM
v8ramair's Avatar
Default Misfire DTCs after dealer TSB
First off, thanks to all who replied to my engine oil questions. I ended up buying the car because everything checked out and it passed smog well. It's a 2007 A4 Quattro 2.0T automatic.
However, the first night I took the car home, guess what - Check engine. I contacted the previous owner (she is very honest, and I do believe her) that the light was never on prevously. I believe her because when she smogged it at an Audi dealer on Monday, it passed. Even with a pending code, it would have failed. However, during the time of the smog, the dealer worked on a TSB for the ignition coils. I have to dig up the TSB #. I have a feeling that is not a coincidence. Here are the codes I scanned:
P0171 - Too lean
P0300 - Random/multiple misfires
P0301 - Cyl 1 misfire
P0302 - Cyl 2 misfire
P0303 - Cyl 3 misfire
P0304 - Cyl 4 misfire
P0441 - Charcoal canister
With the exception of the last one, it sounds like it's misfiring (although it seems to be running ok). Being new to the A4s, should I contact the same dealer and see if they'll look at it for free (which I highly doubt), or should I look for something in particular?
Thanks in advance.
Old May 1, 2011 | 02:24 PM
2wdBlazer's Avatar
If it's a bad coil it will be free. Maybe all the coils have not been changed from the recall.
Old May 2, 2011 | 12:52 PM
v8ramair's Avatar
So the recall # is J1/28F2. It appears that they replaced an ignition coil (or coils) and now I'm getting misfire DTCs. I am just worried they will try to pretend it's not a coincidence, and I'll have to pay for diagnostics and replacement. I could do the work myself if they try to pull that.
Old May 3, 2011 | 11:59 AM
2wdBlazer's Avatar
All coils need to be done. Ask them to run the vin and see what you have had done. When I had my first coil changed they only replaced the failed one and left the others in. I had another fail the next week and demanded they change the other 3.
Old May 3, 2011 | 07:46 PM
Audi Tek's Avatar
Tech Certified
They would have replaced all your coils....
p0171 is a vacuum leak..... which is causing your misfires.... typically from the breather valve on a 2.0
Old May 14, 2011 | 03:49 PM
v8ramair's Avatar
Thanks for everyone's help. It was the PCV valve, and replacing it fixed the issue. No more misfires and DTCs are all gone.
PacificA4
Jun 7, 2012 05:30 PM
adhansel
Aug 6, 2009 09:48 PM
gio gio
Jan 2, 2008 03:50 PM
bvass
Jul 28, 2005 10:51 PM
