ESP / Dynamic Steering Fault??
Old Mar 16, 2015 | 03:58 AM
macaskj25's Avatar
Question ESP / Dynamic Steering Fault??
Hi Everyone,
New to this, however, thought this would be the best place to answer any Audi related issues.
I drive a 2008 Audi A4 3.0 Quattro (B8) and I have just fitted new front discs and pads and new tyres. It has driven approximately 200 miles and when I fired the car up, ESP Fault (See owners manual) popped up on the display. Also noticed that the braking guard and the dynamic steering are disabled. The adaptive cruise control is also not working.
The ESP light is on continuously on the dash along with the dynamic steering light.
Has anyone had this issue before that can give me some guidance?
Thanks in advance.
Old Mar 24, 2015 | 01:18 AM
alex.tvr's Avatar
Any update on your issues, just has this happen to my 2008 S5. Had new front tyres and a full wheel alignment a few hundred miles ago. My steering wheel also put itself off centre by approx a 1/8 turn wheel the errors flashed up.
Old Mar 25, 2015 | 03:43 AM
macaskj25's Avatar
Hi,
No update at all....
Now that you mention it, my steering is slightly off centre, but it has always been like this.
I have a handheld computer, Vgate Scan, and it has come up with the following:
03110 - DTC definitions not found! Please refer to vehicle service manual.
Not even sure if this means anything... After putting the code into Google, it relates to the active steering module..
Anybody out there with any solution???
Old Mar 25, 2015 | 04:19 AM
alex.tvr's Avatar
Post
http://www.scribd.com/doc/256886300/...he-Audi-A4-08#
Probably won't solve your issue, but some background reading I found online - had to sign up, but was free....
My car currently in with Audi agent (luckily I have a warranty!!), I'll keep you posted on what they find.
Old Mar 26, 2015 | 07:48 AM
macaskj25's Avatar
Yes, that would be great. Let me know what they came up with.
Thanks
Old Mar 28, 2015 | 05:16 PM
alex.tvr's Avatar
Seems to have been solved by them doing a 'Basic Setting' on the dynamic steering. They did take a few things apart and look for anything wrong, but in the end looks like electronics just needed resetting and Audi to make some money
Old Mar 29, 2015 | 10:38 PM
alex.tvr's Avatar
Old May 19, 2015 | 03:53 AM
macaskj25's Avatar
Thanks for the info Alex. Car is booked in for a wheel alignment check now and a diagnostic check to done on completion and with the info you provided, I can ask them to check the basic settings with the dynamic steering module.
Old Jul 13, 2019 | 02:34 AM
Doug Lehman's Avatar
Default Audi B8 09 ESP active steering fault traction control light on as well
What did you do to fix? New module or did they do something else? Can this be done without Audi involved?
Thanks
ICORN25
Jul 13, 2019 02:27 AM
TURBO_S2K
Feb 19, 2012 08:38 AM
nik000
Dec 15, 2010 12:37 AM
dale55
Sep 20, 2010 09:18 AM
Blade69
Aug 30, 2007 02:28 PM
