audi 90 (1995) no power
the car in park with pedal to the metal will hit 4500rpm max and it does that very groggy has good MAF, injectors, compression ect also smokes a bit from the oil filler cap when you take it off and after it warms up it makes a slight ticking (sounds like a backfire i think) and smells of gas my engine check light turns on and goes out intermittently then when i run the computer codes i get a 2341 and a 2342 both have to do with the o2 sensors yet then i reset the computer and had them unplugged and got the same groggy engine and even though they were unplugged i got no check engine light is my computer bad? where is it located? ect any help appreciated -thanks ---cliff
i actually have not checked fuel pressure it seems to be fine for the injectors on the left even with the right ones unplugged it still runs poorly then if i unplug one on the left (near the fuel in line it putters and dies could this be bad fuel pump? could this explian why the computer says everything is fine?
Scrottocks
Jun 11, 2014 08:54 PM
brettmichaelsmith
Apr 7, 2014 11:00 PM
