Brake problems
Old 04-14-2008, 09:43 PM
Comrade Casey's Avatar
Default Brake problems
Car:
1987 5000 CS
2.2L Turbo
5 speed manual
Quattro
~187k miles
Problem:
The car recently started displaying the warning light that says BRAKE within a red triangle, complete with three warning beeps. I've checked the brake fluid level, it's fine, made sure the belts are all there, and the brakes are working just as fine as before the light came on. Is there anything I'm missing? And if there is, should I take it to a mechanic or can I do it. Any help is greatly appreciated.
Old 04-14-2008, 11:20 PM
TurboRhatt's Avatar
Default RE: Brake problems
Have you checked the power steering fluid??? The Vaccume boost is supplied by the pump that drives the power steering, I had a similar problem on my 86 CS Turbo Wagon...
Old 04-15-2008, 12:53 AM
Yentemad's Avatar
check the hydraulic oil level, and it is very possible you need a new bomb. that light beeps when the pressure is not correct in the hydraulic system, meaning brakes could be compromised....
Old 04-15-2008, 01:52 AM
I think this may be the problem, the stick that dips down into the fluid broke off (previous owner) and the computer is probably not getting an accurate reading. And my brakes have been working just as good as when I changed the pads last (before the light was going off) so that makes me think its not the bomb. Unless I wouldn't notice that the bomb is going out. Anyways, I just bought a used cap off of a wrecking yard, I'll install it soon as I can. Thanks for the help guys, hopefully this will work.
mcmoore1967
01-16-2011 04:29 PM
lisachapman
03-12-2008 03:38 PM
moeron7
03-08-2007 06:24 PM
yellow325ix
01-03-2007 12:10 AM
A4PLAYIN
03-24-2006 08:58 PM
Quick Reply: Brake problems
