$10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
Old Mar 3, 2016 | 04:19 AM
Timmy Reilly's Avatar
Default $10,000 Service Estimate from Dealer? or should I try my luck somewhere else? [2001 A
I received this service estimate for my 2001 Audi A4 at a dealership after a check engine light went on and I needed a new key programmed.
What do you think?
Additional items noticed during inspection:
  • Valve cover & camshaft tensioner gaskets leaking ($1375)
  • Engine mounts collapsed ($1110)
  • Pollen filter dirty ($95)
  • Crankcase breather hose leaking ($475)
  • Coolant reservoir leaking ($190)
  • High pressure power steering hose leaking ($610)
  • Both catalytic converters failed ($3600)
  • Both left & right front outer cv boots torn ($495 each)
  • All 4 door speakers ($1450)
Plus original estimate of $398.45 (for oil change, check engine light diagnosis, key programming, and key battery)
Should I drop the coin?
Take it to different place?
Find a new car?
My current plan is to call around tomorrow for some more estimates.
Any ideas, experience, wisdom to share?
Old Apr 30, 2016 | 05:12 PM
CRAZYHAWK's Avatar
Old May 7, 2016 | 09:52 PM
ImTheDevil's Avatar
You're getting raked over the coals on repairs that exceed the value of the car. Order a pollen filter and a coolant tank from RockAuto for probably $40 total, take 10 minutes, and replace them yourself. Most of the rest is well within the abilities of the average DIYer too. In any event, their prices are practically a felony. Go elsewhere.
Old May 29, 2016 | 05:36 PM
Deitus's Avatar
I agree with the other members. That sort of coin to put down isn't a worthy investment. Find a good independent mechanic for a 2nd opinion. Just an FYI as an example, I paid $120.00 each for CV boots for my '03 A6 4.2..keep doing the math with the rest of the items and you can see you're paying a massive markup to the dealership.
Old Apr 9, 2018 | 07:42 AM
Arn560's Avatar
Where are you located? Dealer is trying to rape you!
joenelson7687
Nov 8, 2010 06:30 PM
kakashisan
Feb 25, 2008 09:47 PM
AudiA4Girly
Dec 17, 2007 02:43 PM
