i need some ideas
well i have alot of static when i have the radio on at a low level is there a way to get a better ground or something ? or is there a way to hook something up to it to clean up the sound ??
Do you have an aftermarket headunit? If so, try moving the ground around to see if you can get rid of the static at low volume. If not. you can always buy a signal booster - crutchfield.com has them.
its the stock unit and it has the static with the radio on or with a cd in bascily if the system is on and the volume is low its making noise i dont have the cd changer in the trunk so could that open connetion have something to do with it
Yes also buy a Ground Loop isolator for the radio. That will minimise ground noise also.
And looking back on your comment about previous owner having a nice system.
He might have had all the wires in and then hwen he took it out he yanked them all out with no care and pinched,crossed,cut, or disconnected some wires that you cant see running through the car.
Just another angle to look into.
yeah there are to cuts in the floorin the back seats can lift the carpitting up and see some wires, is there an easy was to take out the radio so i can get behind it to look at the wires and add a ground loop isolater or should i be looking in the doors to see how the connetions are to the speakers
