i need some ideas
Old Jul 4, 2007 | 01:56 AM
01 S4's Avatar
Default i need some ideas
well i have alot of static when i have the radio on at a low level is there a way to get a better ground or something ? or is there a way to hook something up to it to clean up the sound ??
Old Jul 4, 2007 | 12:15 PM
A4 Effort's Avatar
Default RE: i need some ideas
Do you have an aftermarket headunit? If so, try moving the ground around to see if you can get rid of the static at low volume. If not. you can always buy a signal booster - crutchfield.com has them.
Old Jul 4, 2007 | 11:21 PM
01 S4's Avatar
its the stock unit and it has the static with the radio on or with a cd in bascily if the system is on and the volume is low its making noise i dont have the cd changer in the trunk so could that open connetion have something to do with it
Old Jul 5, 2007 | 12:35 AM
TKneedsS4's Avatar
Yea sounds like your power ac wire is jumping or tripping off one of the speaker wires. they mght just be like pinched really close together somewhere or something real dumb like that.
Old Jul 5, 2007 | 05:48 PM
01 S4's Avatar
thanks for that idea im thinking who ever had the car before me had a nice system in it and had it taken out before he traded it in might be something small like that somewhere
Old Jul 6, 2007 | 03:16 AM
csuflyboy's Avatar
Double check the ground wire on the back of the OEM H/U is connected.
Old Jul 7, 2007 | 08:53 PM
TKneedsS4's Avatar
Yes also buy a Ground Loop isolator for the radio. That will minimise ground noise also.
And looking back on your comment about previous owner having a nice system.
He might have had all the wires in and then hwen he took it out he yanked them all out with no care and pinched,crossed,cut, or disconnected some wires that you cant see running through the car.
Just another angle to look into.
Old Jul 9, 2007 | 12:01 AM
01 S4's Avatar
yeah there are to cuts in the floorin the back seats can lift the carpitting up and see some wires, is there an easy was to take out the radio so i can get behind it to look at the wires and add a ground loop isolater or should i be looking in the doors to see how the connetions are to the speakers
B6A4Ohio
Feb 10, 2011 04:22 AM
B6A4Ohio
Nov 26, 2010 05:26 PM
Crekuc
Nov 3, 2008 09:59 PM
chefnic26
May 30, 2007 10:54 PM
shkenned
May 21, 2007 11:58 PM
