subwoofer mounting
Old Nov 13, 2008 | 02:47 AM
Quattro_1.8t's Avatar
Default subwoofer mounting
So whats everyone on here do to hold down their subs so they don't come unplugged and hit the back of the trunk? I use the cargo net right now but it still slides around a bit. I used to have the box drilled into the trunk but I drilled the gas tank and had that plugged back up. I do not want to drill if I dont have to. I have a single 10''
Old Nov 19, 2008 | 03:28 PM
jlaudio184's Avatar
Hate to say it... but just drill 2 - L brackets onto your box, and just drill carefully when screwing it in.
I did it on both of my car's, without problems of drilling the tank. Just use care and check where your drilling before you do it.
Old Nov 19, 2008 | 03:47 PM
betes's Avatar
ya use l brackets but do it on the sides of the box that way you increase your chances of NOT hitting the gas tank
Old Nov 28, 2008 | 05:49 PM
ambesolman's Avatar
Member
ya i got 1 L bracket holding mine in the back left corner up against the rear of the seat
Old Dec 6, 2008 | 09:34 PM
ragnaroksq's Avatar
I have an Infinite Baffle setup. In my opinion, this setup sounds the best. the only con i can think of is that it lowers the power handling of the subwoofer, but the frequency response is very smooth
Old Dec 27, 2008 | 11:29 PM
Prizmatik's Avatar
I have used some non-slip fabric on my 2 12" sub box and it works very well. It may be slightly different for a single 10" or 12", but it allows it not to slip or tip. You can purchase the non slip fabric anywhere, I got mine at Wal-Mart.
Old Dec 30, 2008 | 01:52 AM
dataudikid's Avatar
I have heard a shower mat holds it in place without anny screws!
Old Dec 30, 2008 | 12:56 PM
pa4ul's Avatar
I post pics of how i braced my box in my trunk. I got all new speakers and amp and cap and rebuilt everything from the ground up all done at home. nothing moves or slides and i didnt have to drill on hole in the body. pics be up soon.
Old Dec 31, 2008 | 11:17 AM
cdowns13's Avatar
Member
well a few things you could do is:
1. velcro under the box (may need to staple it on to stick under the box and use like 4 pieces of the heavy duty stuff
2. i have heard people of screming screws from inside the box down through the bottom so to leave a little part of the screw protruding from the bottom.. multiple of those i would say if u went that route..
i would say just use the velcro it would be easiest
i would use it on mine but my box takes my whole trunk up with about a foot of room so yeah.. but have had many other systems and do all my friends and know the velcro thing works.. had to use it on a 5.6cu box in my old SUV
james0013
May 31, 2008 10:56 PM
Blade69
Nov 19, 2007 10:04 PM
munkee
Mar 15, 2007 11:18 PM
Silver98A4
Jan 13, 2006 01:21 AM
Fieldy
Apr 20, 2005 09:14 PM
