cambelt stripped teeth
Old Apr 19, 2012 | 11:58 AM
cjdtech's Avatar
Default cambelt stripped teeth
was wondering if anyone could tell me whats the chances of a 2001 1.8 a4 avant not having hit valves when the cambelt stripped cars was doing about 100 km/h and if theres a way of checking it without taking the head off
thanks
Old Apr 19, 2012 | 12:48 PM
shipo's Avatar
I'm thinking the chances are about zero.
As for checking while the head is still on; no problem, find a shop with bore scope equipment (they can image the cylinder via the spark plug hole).
Old Apr 19, 2012 | 08:57 PM
M5S5's Avatar
Tech Certified
Chances are Slim & None!
Old Apr 20, 2012 | 05:09 PM
mattez69's Avatar
ooops, interference engine, simple compression test will suffice, also chances are it has shattered the valves depending on how high the revs were. If so, game over complete new block rather than just head.
Old Apr 21, 2012 | 09:24 AM
cjdtech's Avatar
thought as much
the scope is a bit of a problem as my workshop doesn't have on but thanks
Old Apr 21, 2012 | 05:35 PM
ImTheDevil's Avatar
Just compression check it. That'll tell you. If the valves are destroyed the head will need to come off anyway. That'll let you see the cylinders and decide if you can salvage the short block.
Old Apr 21, 2012 | 07:27 PM
shipo's Avatar
I'm thinking that to perform a compression test the OP would have to go through the bother of putting a new timing belt on an engine which probably needs major work.
Old Apr 21, 2012 | 07:33 PM
M5S5's Avatar
Tech Certified
Compression test is not possible without proper alignment of camshaft to crank.
A leak down test is possible but not too many diyers have a leak down tester.
I would remove the valve cover & look for excessive clearance between the cams & the followers , that will be a sure sign of valve damage.
Old Apr 21, 2012 | 09:43 PM
ImTheDevil's Avatar
Agreed with shipo and M5S5. Sorry for the brainfart.
JEDGE1.8T
Oct 31, 2014 10:21 AM
wowdi
Mar 17, 2008 03:32 AM
trollbooster
Oct 15, 2007 01:38 PM
NLT1.8T
Jul 25, 2005 01:44 AM
