Interior What have you done to the inside of your ride? Customized it? Kept it super clean? Talk about it here.
Boost Gauge Install - Electrical Problem
Old Mar 3, 2008 | 09:36 PM
akordboy's Avatar
Default Boost Gauge Install - Electrical Problem
Wired up my boost gauge tonight. Pretty straight forward, so I thought. I connected the white wire to the blue/gray via a wire tape. Then I connected the ground to a brown ground wire on the left side right below the fuse panel via the other wire tap. Turned the key on and nothing. So I took the ground wire used for the gauge ground off the post. As soon as I did that, the gauge lights up. I put it back on and it went out. So I cut the gauge ground from the tap, put a ring termal and connected it to the post described on AWE's web site. Still didn't come on. I give up.
Any ideas as to what is going on?? TIA.
Jeff....................
Old Feb 18, 2009 | 10:31 AM
Mattazaudi's Avatar
do you have a test probe so you can verify the polarity of power on the wires your tapping?and as far as the ground just use a ring terminal and a self tapping screw and screw it to any metal so it has a true gound to the chassis.
Old Feb 25, 2009 | 03:25 PM
brrman's Avatar
which blue/gray wire is this?
Mr. Phil
Feb 15, 2011 09:59 PM
TommyGunns
May 3, 2009 02:29 PM
jaymac
Sep 5, 2008 06:19 PM
joshuo
Nov 18, 2007 07:25 PM
fenderstrat1184
Dec 21, 2006 02:35 AM
